Hi, I am having bed adhesion issues on my BBL A1M. I have tried adding a massive brim, supports, and slowing down print speeds. But I am not sure why it is failing. I have attached pics below.
I am using 0.08mm layer height preset and BBL PLA Basic. I also have a Textured PEI Plate. I am also using a 0.4mm nozzle (Stainless Steel). Washing it with soap is my last option, but I wanted to see if there are any other solutions besides this.
That’s not an adhesion issue, that’s a orientation issue.
You have no part of the model touching the bed, meaning it is held up only by supports.
Supports are made to break away, see where I’m going here…??
Washing the plate with soap and water is a bit of a must-do on a bed slinger with a print like this. You can’t expect this to print with a dirty build plate.
Glue stick & water may help as well (on a clean plate).
Finally, just in case it is the supports that break, increase support wall count. In extremes such as this, you may also need to decrease speed and/or support interface z-spacing. The latter may be avoidable if printing the modell flat, with a dissimar material support interface material at 0mm z-distance.
And of course you could split the model into two halves for easier printing with direct model-build plate contact and glue the halves together.
Yes I understand, but when I rotate where more of the model is touching the plate, Bambu Studio automatically puts sparse infill on top, ruining the aesthetic of the model.
And the layer height is a typo, I did it at 0.08mm (High Quality) preset in Bambu Studio.
The picture I have attached is a screenshot from Bambu Studio. The red part is labeled as “sparse infill”. This ruins the visual quality of the wings, and I am not sure how to fix that.
Put the model back up where it was in your original photos.
Imagine you are holding the model with your fingers at the very front of the place (the top of the model as on the plate)
Twist your hands so one wing faces backwards and the other faces forward.
This will create a transverse force against what you originally had.
The idea is to use the increased length of the mass your plane generates to stop it from tipping over. Having one wing at the back and one at the front makes the bed-slinging motion less able to tip over the model as it is like standing with one foot back and the other forward when you aim to catch something big. If your feet were next to each other, you are not braced against that force.
Increasing ‘support wall loops’ might also help. It’ll waste more material, but setting it to 1 (from default of 0), will make the tree supports considerably stronger and strong enough to support the model.
[Edit: Ah looks like Malc already said this, but] If you print it standing it, I would also rotate it 90 degrees around Z from your original picture so the movement of the bed is aligned with the width of the aircraft. This so the inertia trying to separate the plane from the bed acts along the longest axis of the supports.
