Bed leveling louder on one side
This just recently started. When the X1C is going through the bed leveling routine, the left side is MUCH louder than the right. It is specifically the little bed “taps” it does. Then the nozzle makes it to the right hand side it sounds normal.
I recently re-greased all three of the z-axis, and I’m about to re grease the left one again for good measure. I also cleaned the rods which involved loosening the belts (but prints are normal otherwise, and x / y movement sounds fine)
I was wondering if anyone has any experience with this or knowledge on it.
It might be worth performing a manual bed leveling to make the bed mostly level. That would minimize the amount of automatic compensation needed.
Unless there is some other indication of a problem, I don’t think I’d worry about the sound effects.
