Bed too sticky for PLA
using the cool sheet for pla, and i can not get the items off easily. Is there a trick? Bending the sheet is very hard as they are stuck too well
Did you use the glue stick like they say? I’ve had no issues doing that. The glue stick to help release the print otherwise it sticks too well.
Wash the cool sheet with dish soap and warm water and dry completely. Spray your cool plate with Final Net hair spray 2 light coats. Your PLA will come off without a problem. BTW I just find glue while it works, is just nasty to clean and reapply.
thanks ill give both a try. i have not used hairspray on a plate in a few years.
That is why people have ordered either the textured PEI sheet or another PEI sheet with even surface, like the one fom Energetic.
If you use the PEI plate NO glue is required. PLA & PETG stick great while printing and will pop off when the plate is flexed just a little bit.
