The Bambulab store says 100-140C, which is a very wide range:
but the advice on the Bambulab PPS-CF packaging says 120C plus/minus 10C, which is also a wide range, but somewhat contradicts the advice from the Bambulab store, because it would exclude 131-140C.
I need just one number. What is the Best number? Should I go for 130C since that’s the highest number that meets both sets of constraints? Or do neither set of instructions know what they’re talking about?
Simple rule here. Hotter means faster drying. What is important is that you stay below the glass transition temperature (Tg) of the material.
Otherwise your filament starts to deform.
I need a number, not a ride… I mean, I need a number, not a theory.
I would say 120 degrees C then.
Also what are you using to dry it? I hope its a proper blast oven with good temp control. I did print some Fiberon/Polymaker PPS-CF straight from the packaging and it came out good. The Bambu PPA-CF was a different story and needed drying.
Yes, a proper blast oven very similar to what Clough42 has.
I would fillow what it says on the roll because that was probably set by the actual manufacturer of the filament. I would personally set it to 110-115 and test.
You can always try a higher temp if it doesnt work. Hard to go back and try again when its melted together. Plus the oven may have hot spots
I’d go with 130C as a safe middle ground. It’s the highest number that fits within both recommendations.
This is the particular blast oven model that I have:
Even though it says 1000w, it can draw just over 1500w when heating up initially. I suspect that the only meaningful difference between it and the one Clough42 has is that his may have an additional fail-safe cut-off thermal switch.
