I’ve been using some metal files I had lying around to sand my prints.
What do you all use to sand your prints, just sandpaper and a wooden block? Is there anything good for sanding?
Thanks in advance.
Thanks in advance.
I use the following depending on the print:
Mini metal file set a various shapes
Hard paper nail files
Sheets of sandpaper sheets or small folded pieces
The most important thing is often overlooked:
Manually setting the orientation and support and increasing the print quality can really make a difference to avoid sanding for the most part. So my sequence is:
