I’m able to easily increase the temperature and wait between layers using M109 S[Temp] but I’m not able to reduce the temperate using M109 R[Temp] for some reason even though slicer shows it’s changing temp. The P1S just doesn’t seem to respond to the R Code?
Does the Bambulab have another implementation that’s better to use or am I not understanding what R is used for? Thanks in advance!
After a little testing, M109 S[lower temp] works fine but it doesn’t wait for the temp. I added a G4 P10000 for waiting after and that seems to work OK. Kind of a hammer when a scalpel would do. All this work was mostly for printing a temp tower! thanks for the specific code link
Thank you for sharing the experience.
I am glad to read that the M109 S works and surprised about the M400’s failure.
I need to find out how the printer starts. G-code entails waiting.
I thought that was the M400, even if not typical.
To clarify, I didn’t test the m400 code. I had already tested a dwell with g4 wait statements.
The m109 R[temp] lacking is a bummer. Especially that slicer interprets it. Using M109 S[temp] for lowering temperature is no different than m104 to my understanding.
