Beta testers for P1 series firmware!
I do not know, why it is so difficult to simply post the release notes to this forum?
Here you (all) go:
Version OTA 01.05.04.00:
[New features)
  1. Non-LAN binding via PIN code on the studio side (in conjunction with Bambu Studio v01.09 Beta4 and up).Users can bind P1 devices to the computer that is not on the same local area network (LAN) using a PIN code on the studio side
  2. Improved manual flow calibration parameters management. (in conjunction with Bambu Studio v01.09 Beta3 and up) Auto-save the manual flow calibration parameters; Support creating managing new PA parameters; Support setting PA configuration files on the filament settings page
  3. Third-party filament support.Users can create and manage custom filament profiles in Studio. These custom filaments can then be selected in Device filament slots
  4. Device name display.Custom device names from Handy or Studio can be displayed in the settings menu
  5. Added carbon rods lead screws maintenance notice
  6. Improved color display for gradient and dual-color filaments
  7. Auto filament verification when printing with 3M files from an SD card
[Feature Optimizations)
  1. Added secondary confirmation when stopping a print
  2. Added switch to join/exit experience program in the Device menu
  3. Optimized Total Print Time Calculation
  4. Revised HMS display, added heatbed abnormal protection
  5. Added filament verification for “Reducing purging through retracting filament”
function
A long retraction during filament change can significantly reduce the purge volume, but it may cause clogging when the filaments assigned in the sliced file do not completely match the actual filaments in use. The filament verification function will verify the filaments match before performing retraction.
This function needs to be used with the slice files generated by Bambu studio v01.09 (Beta4) and above. For more information about the “Reducing purging through retracting filament” function, please refer to the Bambu studio release notes [Releases · bambulab/BambuStudio · GitHub].
[Bug fixes)
  1. Fixed the glitch when formatting the SD card
  2. Fixed intermittent black screen after power-loss recovery
  3. Optimized FW update printer status check for safer update
  4. Optimized status verification when downloading a language package to avoid process conflict
Just pushing this out but would like to be a part of the P1S Beta program if that has any openings:
Long time MS Windows Insider beta tester and enjoy it.
