- Detailed description of the problem
- Printer model used
- Slicer settings used
- Type of filament used
- Photos that clearly show the problem
- .3mf file (if the file can be shared)
- Any potentially useful information that is related to the problem
Ok, so I’ve had the bambu a1 mini for around a year now, mostly printing with pla. So when I started printing with petg a few weeks ago, I was like, no biggie, this is going to be fine. Little did I know that my complacency was going to bite me in the butt when I didn’t make sure to see if a multi-hour long print would stick, and I came back to a ball of doom. Is there anyway I could salvage this?
I will add:
Always keep a spare Hotend Heating Assembly around. Blobs like this like to break the heater and thermistor wires, or not really the blob itself but the process of removing it.
Looks savable.
Youll definitely need a new silicone sock, very likely a new nozzle id be shocked if this one isnt bent in some way, very likely a new parts fan/shroud but not enough pics to tell, and maybe also a hotend heating assembly if the wires got damaged. Should be fine, good luck!
Youll be in a much better shape to clean it up if it will heat up by itself. Set the nozzle, go make a cup of tea, and then start picking off the melting bits. If it can’t, then youll have to get creative
Soldering iron can help melt but be very careful. Try to dig in to find the metal nozzle, then touch tip of the iron to the nozzle for a minute or so to be a “fake” heater.
