Hi
We ordered a blank spool from Bambu Lab but we can’t get it to connect together properly with the filament on it.
The lugs here look deformed is this what’s causing it not to lock in do you think?
Thanks!
Hi
Thanks!
Here’s a video walkthrough. Refill Filament with Bambu Reusable Spool / Refill | Bambu Lab Wiki
In my experience, there are two key parts to keep in mind:
In some cases however, the cardboard has been cut with worn tools. A bad cardboard edge will make it very difficult to install the refill on the spool. There are helpers on Makerworld though.
Finally, after latching the spoll closed and before removing the tabs, you may want to give the filament a good massage. Sounds strange, but it does help against entanglement. And “AMS savers” can help against that as well.
