Blue Box on build Plate
I have been getting a “Blue box outline” showing up as I load a file. I noticed it when I download Bambu’s setting for “Vace” settings when printing Active LW-PLA.
Cannot load pic.
Thanks
The blue lines are the outlines of the regions where you can print the object when selected to print by object, instead of regular. You need to select print by object if you’ve selected spiral vase. It becomes a problem, if trying to print more than one object, unless you understand the clearances needed by the print head. The implementation is not as good as it could be.
thank you verry much for this trick.
