Ich habe bei einer Vase die Wandstärke auf 3mm gestellt. Der Boden der Vase wurde jedoch nur 1mm stark gedruckt. Muss das separat eingestellt werden?
This is quite common issue, I’ve had this problem several times. I couldn’t make the bottom thicker in Make My Vase, but I fixed it in Slicer.
But how do you do that if the shape is not round but has waves?
Then the trick becomes to double the item, then cut the top off so that only bottom remains then scale the remaining bottom up, then join the bottom with the part and center both, then position the thick bottom in a way that you want it and slice.
Quite complicated but works for me every time ![]()
Who could you tell about the need to fix the bug?
You’d need to create another topic with #bug-report tag that’s for sure. Annoying part is: not all MakeMyVase come out with razor-thin or non-existing bottoms so that’s not as repeatable as debugging goes…
