Brand New Doesn't Print
I set the printer up and attempted to print a first print. It went through its calibration etc. Then when it should be extruding filament, there is nothing. It then is a warning that the lidar didn’t detect anything, It then said I was out of filament.I swapped another roll and still same errors. There is a red light on the AMS that flashes on all of the spool nozzles, regardless if there is anything loaded or not if that matters. Any advice ?
There seems to be a weird behavior if the printer acted in the way you describe it. There are several sensor build in that should throw messages. Anyhow, as you describe that all 4 AMS slots are blinking red there is maybe something wrong with the AMS connection - can you check this guide: AMS is not detected by the printer | Bambu Lab Wiki
And out of interest: Does the extruder LED (right side on the Temp/Axis tab) shows a green or grey light? Green would indicate it detects filament in the extruder, grey: no filament.
And did you hear any noise during print start? Maybe as the AMS is not correctly connected, it did feed filament but then stopped to refeed in sync with the extruder.
try printing without the AMS and rule that out
Thank Y’all for the assistance. There was a small piece of wrapping that got stuck inside the connector for the AMS I found after disconnecting the AMS and trying to reconnect it. A good connection always helps
