Broke Filament help
Can anyone give me some advice on how to remove a peice of broken filamnet out of the feeder motor. I had a peice of filament break off, I have found how to remove out of the petf, from inside the AMS, but not the feeder motor. I have attached a pic, you can see the green filament, I think it is just a inch long or so, long enough to cause havok. Any sugestions
Disconnect your PTFE at the back and push it through with another piece of filament.
Worst case, if it doesn’t push all the way through you may need to disassemble the AMS to get to wherever the little bit ends up.
