While changing out the two prong wire for the heater the little plastic retention clips on the top broke, now this is probably, due to maintenance, switching nozzle sizes and clog fixes my 75th or so time taking out the hot end on this unit. The wire will obviously not stay plugged in. What is the replacement part that I need? Thank you
If you just wish to replace the Extruder Interface Board, it is recommended to buy this:
The comment above shows the entire TH board set, which would not be required in this case, if the only problem is related to the connector damage.
Thanks Support, learned something.
I replaced the interface board and redid all the connections and am getting what seems like every imaginable error message and the unit will not go into self check for me. I have reinspected all connections and all seems good. I redid the connection at the FPC cable with the same result.
It is recommended to double check the ribbon cable connecting the two boards.
The errors seen show a lack of connectivity to the Extruder Interface Board
