Broken filament
Hello,
As the filament cannot be pushed through to the extruder, I have realised that it has broken off at the back of the tube that comes from the AMS and leads into the screwed-on connecting part.
How can I detach the hose from this part?
Kind regards
ProApe
Disconnect the PTFE tubes from the buffer and pull out the broken filament.
You might need a screwdriver to push in the PTFE connectors.
As an alternative you can print this tool (or something similar) as soon as your printer is up and running again.
How?
I don’t find any instructions for doing that.
The PTFE tube is inserted in a connector. At the entrance of the connector there is a collet around the connector. You need to push the collet towards the buffer (using a screwdriver or the 3D printed tool I posted). While holding the collet pushed in you can now retrct the PTFE tube from the connector.
Thank you, I have succeeded!
@proape Print one of these for next time (X1 / P1 Combo Tool by Generic User - MakerWorld)
ok, thank you to you both
