Broken flow dynamics calibration?
Under the calibrations tab at the top, when i select “flow dynamics” and click Manual Calibration at the bottom, then set my parameters, and then click Calibrate, it just goes to the next screen showing what the calibration will look like, but then just show N/A, Layer:N/A N/A underneath? Im assuming this is when it should be printing the calibration, but it never actually starts anything?
I have an X1C but i did try the manual calibration. Went thru the settings and clicked calibrate. It started heating up the bed. Just the same with auto calibrate.
Ok, im guessing its specific to the P1P, since we only have the option for manual, we dont get any auto anything.
I’m having the same problem. Flow rate calibration seems to work fine but the flow dynamics just gets stuck and never works. I’m hoping Bambu is working on this.
I have a P1P. I ran into the same thing seeing N/A, but then I heard my print bed move and then it was preheating. Not sure if I didn’t let it just run in the past, but this time it seemed fine as it was preheating.
Yeah, now today i just ran it, and the bed just moved. when i checked in Bambu Studio, it now shows 1%. Yesterday i let it sit at N/A for at least 15 minutes, so im not sure why its working now. I havent even restarted the printer since yesterday when it wouldnt work.
I think the problem is with the latest slicer version. I had the same problem, then downloaded Orcaslicer 1.6.4 and was able to successfully run the dynamic flow calibration.
