Today I encountered a strange bug when uploading the assembly instructions for one of my model as a gif - animation.
There is a specific frame where the time is set to 2 seconds for freezing the animation and showing some text. The strange thing is, that in the editing stage, the .gif behaves like it should. When saving the time on this frame is overridden somehow (maybe happens by converting it to wepp).
The other strange thing is, that on the two other .
gifs the freezing frames seems to work like intended.
I know I could fix it by dublicating the frame, but I wanted to leave it a few days for @makerworld to take a look at it what could be wrong there.
The Model in question:
The gif: (exactly the same as on the model and here in the forum it seems to work)
Sharing this information out is the right thing to do. @MakerWorld isn’t converting the gifs correctly to respect frame timings. Should be an easy fix.
Today I recognized that the other two assembly gifs of this model won’t play as intended. They have now a framerate of 2 seconds. I don’t know since when this issue appeard but, they worked before.
When I open the model in edit mode they seem to play in normal speed.
