The setup: ABS-GF and support for ABS, both loaded in .4 standard nozzles.
The problem: the support material only shows up as an option after slicing if I turn on multi-diameter mode. Apparently, multi-diameter mode chooses wall count for you? So is a useless addition unless you like weak parts. The part snapped within 10 minutes and looked like it had one wall
