when I bought the combo sheets I noticed it only came with 1 plate, so I also bought extra 3 “Bambu Smooth PEI Plates”. I got the package today and I noticed that the plate that came with the sheets is different than the one that came with the combo, its much thinner and has no writings, I want to know if I can apply the sheets to the thicker plates that bambu calls " Bambu Smooth PEI Plate" on the website. please help
Plates or stickers? The stickers do not have the Steelplate and need to be applied after removing the old surface sticker.
Unfortunately the smooth plate is also basically a sticker, you can tell by the tab area where the nozzle is cleaned. You would need to remove that first I believe, not sure how one would do that or if one would want to though.
Also, the kit with 4 stickers and one plate will serve fine for two stickers, one on each side of the included blank. You could probably find out how to blank one of those smooth plates for the other two stickers.
It will peel. Since they’re new it may not hurt to warm it up first on the printer. Not too hot, but enough to get a scraper under the lip at the front. Once you get started you may get lucky and it come off in one part. Probably won’t. Just take your time.
The stickers will stick, but clean the plate with alcohol first. Be sure to line it up and put it on, cause it pretty much holds right away. If you’re off a bit you can take a craft knife and trim the end overhanging.
