I’m doing the flow calibration but those are the first results.
I’ve only modified the profile for 0.2 and in the printer parts under device, rest is default.
I was hoping to see a clear line like for the 0.4 in the past, all the lines kind of look the same. How should I further aproach this?
I actually came to the forum for similar issues - I’m new to this world, but my A1 Mini has been amazing with the 0.4mm nozzle. I’ve literally had no issues whatsoever in the few weeks I’ve had it.
But I’m having zero luck with the 0.2mm nozzle - and when doing the flow rate I get the same as you, they all look the same and none of them are uniform
Isn’t the step too big? I think it must be 0.01, 0.011, 0.012 … 0.02 and not 0.1, 0.2, 0.3…
Because as I remember on 0.014 my line was clear, and on 0.013 and 0.015 not, and You simply loose that accuracy.
Hey man, i did some basic prints with the “default settings” and it came out good. I think I may have been too much of a good sport and wanted to calibrate responsibly, which may have been an overkill. I did a bust of myself through the makers generator from image. The generated scan looked good and I gave it the height of 50mm. I look like sht but tomorrow morning I will get back to confirm the results
I have a print in WIP with default settings. Tomorrow night I will recalibrate following your instructions and get back with a result. Curious how the current print turns out as the test cube turned out perfectly on default
