Calibrating TPU Pressure Advance/Flow Dynamics no effect
I am trying to calibrate Pressure Advance/Flow Dynamics for Generic TPU. There is absolute 0 effect. It just looks like the Pressure Advance/K Value isnt changed at all through the calibrating process. I tried Bambu Studio and Orca slicer. Tried Line, Pattern and PA Tower. I googled a lot and i am not the only Person. On youtube Peoples having the same Result. In this Forum i also found people with this Problem but i couldnt find a reason or a solution for this. Any help for me?
On my other Printers i dont have this Problem btw
What values are you using for the calibration?
I tried 0 to 0.3. Tried to go higher cause i realy wanted to see any difference but it 0.3 is the maximum allowed
Hmm, that should have shown some differences, are you on the latest version of Orca? They just released a bugfix for the PA tests
Yes I am on 1.9.1. Also i have this problem only with TPU. The Calibration worked fine on PLA/PETG
I had the same issue with Bambu TPU95A and I had to extend the range a lot before I saw a difference but I eventually did. Not sure what 0.3 limit you are referring to but Orca lets me go as high as I want.
My PA for the now discontinued Bambu TPU95A is 0.5 and it prints well.
For example, Orca lets me set a range of 0 to 1 without restrictions:
Try 4.0 ~5.0. it really needs alot, tpu has very little viscosity when liquid
hi [MeicalnissyenMeicalnissyen)did you realy mean 4.0 to 5.0 or just 0,4-0,5?
Unless they use bowden, it’s almost definitel 0.4-0.5
