I just assembled my X1 and have had issues with calibrations. The first Calibration at startup went fine. They heat tray lifted and did its little “dance” and all was well. But after that it has failed. Sometime the heat tray will not go up quite all the way and will try to go through its motions but soon errors out. The heat tray cable is not bound up. Anyone experience this?
Hi Rogm1017,
I have not had this problem.
Did you see any error codes or messages pop up on the display ?
Unplug printer ac cord and check all connections are good and nothing is getting blocked and run the calibration test again and see what happens.
This might help you out.
Yes, i have done all of that multiple times. Its just kinda erratic. I feel something just isnt right with this build. I really don’t feel i should have to troubleshoot a new printer out of box. Have contacted bambulabs fir a return.
