I wanted to to try running the calibration tests in which you can save the settings, but the lidar is still invovled.
I watched a video on how to do it, but when they showed that you have a choice of which filament from the ams you want to calibrate, I looked at my choices, and it only showed the non ams loaded filament as an option.
Any idea how to fix this? The AMS is plugged in and working with normal prints.
I have tried it in both Orca and Bambu slicer. Same result.
What do you mean by “Reset the external filament”? If you are referring to “syncing” the AMS with the slicer, I did a full resync.
I want to do the auto calibration, and save the settings.
I didn’t install the latest firmware, but I have everything up to date except for the latest. Was there a button labeled “reset” in any of the pictures you posted? If not, can you post a pic of where the reset button is?
This may be related, but I have realized that the printer won’t let me load any filament now. I was using the outside spool for some tpu, and now anytime I try to load from the outside spool or the AMS, it just gets stuck at “Pull out the old filament”. There isn’t any in there, so I’m assuming that there may be some stuck, clogged in the extruder. I am really not looking forward to taking apart the extruder. I have some vision and dexterity issues that are going to make this really unpleasant.
