First of all, yes I am new, yes I tried the tech support (they couldn’t explain on the chat) and yes I read wiki pages but I still don’t get it
My setup: H2C + FTS + 2x AMS2Pro
As perfectionist I am with new equipment, I always want to have full calibration for best quality results and at the same time I like to understand how it works. But with the FTS setup, I simply don’t get it when it comes to flow rate and flow dynamics calibration.
Now, I have (for example), calibrated flow rate for a filament type & material on L and R nozzle. The questions here are:
Q1: where can I manage the results (I simply can’t find that like it’s for dynamics)
Q2: do I even need to calibrate this for L and R nozzle or is one nozzle enough
Q3: does printer/slicer automatically chooses the right one?
And then comes flow dynamics which is even more confusing. Manual or automatic configuration - it doesn’t matter. I have it again for each filament type & material calibrated on L and R nozzle. I can see the results here and manage them so that’s fine. But…
Q1: Under Devices → Filaments on the right,“edit” filament, I can choose the PA profile, which shows me two profiles. One for L nozzle and one for R nozzle. I can choose one - fine. But with the FTS, if the filament goes to another nozzle, then what? How does it work?
Q1: Flow rate calibrations are saved as a new material profile for that filament and are based on the filament’s properties. In Prepare, click the filament dropdown, under User Presets your filament should be in the “Custom” section.
For first Q1 - I haven’t correctly explained that; I know where and how to apply but I thought more where to edit/delete them. Turned out… I was looking at it all the time, stupid
Q2 - Cool, I thought so the same
Q3 - That makes sense as well…
Second Q1 - I get that as well - my question is more around the logic and FTS. Can FTS assign the same filament to different nozzles (L or R) during the print? If yes - then the assigned profile (K Value) would be wrong as it can only be assigned L or R right?
Or can FTS not assign filament to different nozzle during print? Then it would make sense… but support couldn’t tell me that.
