So I’ve had to do some manual and auto filament calibration to address a print quality issues. I’ve not needed to look at it before but the array of options is a bit confusing so I have some questions…
1 - on a print if I select the calibration option along with e.g. bed levelling this only calibrates pressure advance right? (not flow rate…??)
2 - If I run a flow dynamics calibration (from calibration menu in Bambu Studio), write the value to a new filament pre-set, use that for a print and then click ‘flow dynamics calibration’ which value does it use?
3 - If I have not done any flow dynamics calibration (via Bambu Studio calibration section) , run a print with this option enabled via the pop-up, then print something else but do not tick this option does it use the last calibrated value?
4 - If I print something, select the ‘flow dynamics’ option is there any way to see the value it used?
5 - Is there a way when loading a filament to select a previously calibrated K value and flow rate quickly/easily?
Any tips on getting/keeping the calibration right. I think it’s probably prudent to run a flow dynamics and flow tests for every new filament (or at least brand + Type) and store these via the profile (and on the printer). I have an AMS so a lot of the time if printing 4 filaments even if I click the flow dynamics option each print at best it calibrates dynamics for only 1 filament…
