Calibration stuck in loop
I have tried to run calibration twice on my P1P, started it in both the app and from bambu studio.
Both times it got stuck and just kept repeating the same movements over and over, the tool head would make diagonal movements in the rear corners. The remaining time didn’t change and after about 20 minutes I used the panel to end the ‘print’.
Anyone else seen this behaviour?
If that were my X1C you were calibrating, I’d say you cancelled the calibration about 30 seconds before it completed.
:rofl:
I can try it again, 3rd time lucky maybe…
I also got an HMS error the first time around, have never seen that before or since.
The same movements over and over sounds like the new motor noise calibration (movements do get faster over time though). On my X1C it takes over 15 minutes alone, so 20 minutes is no longer enough for a full calibration.
I tried it again yesterday and it completed in around 30 minutes, I’m not sure the exact time as I was not watching closely.
The thing that was confusing was that the remaining time, on the screen, was at 9 minutes for a long time. But it seems to have worked so I am happy.
Perhaps there should be some info to explain that the remaining time isn’t accurate as it depends on the process.
Having two issues. 1st hotend wont get hot. Have replaced with new one same issue. Plate does get hot. 2nd issue calibration gets stuck at 24% has anyone has anyone had this issue?
Not same issue having an issue where calibration wont get passed 24% ans hot end wont get hot. Have replaced hot end. Dud you fix your issue?
same- I have tried everything!!! and now I am waiting for parts… very upset
When I start a print IT moves the motors to far and then just repeats the same motion over and over It just started this today and it worked fine yesterday so can I have some help
I’m having the same issue. 24%. I had to replace my hot end fan. not getting the same fan error, but calibration won’t get passed 24%
How in the world can I start a conversation here.
I am having a problem, not related to this one but cannot figure out how to start new discussion???
See Why can't I post in Bambu Lab AMS? - #25 by Aronis
