Calibration won't let me click next
Has anyone had, and solved this problem?
I’m trying the manual calibration, but whether I choose numbers or patterns, the moment the printing is done-- … well, nothing. I can’t press ‘next’, it stays grayed out. I can only press ‘back’ and do it again.
I checked the wiki, but it doesn’t mention extra steps. Do I need to turn the printer off or something, or am I just bugging? It’s been between 5 and 10 minutes since the print finished.
What worked for me was to select the Flow Rate Calibration and then go back to Flow Dynamics Calibration and the Next button appeared.
What worked for me was exiting full screen mode.
I would restart the printer, router for WiFi, and your computer. I’m new to 3d printing and haven’t had this issue occur yet. The photo added shows that the bar towards the bottom isn’t full, so it could be a connection issue. Then again if the calibration was sent to the printer fine, then I’m not so sure. But you should try restarting everything.
i have the same issue. trying to fix it.
I’m having the same issue, “next” is grayd out
Any solutions?
if anyone ends up here from Google in the future - I was able to bypass this by backing out, restarting the calibration 1, and immediately stopping it. I was able to click Next and input my best value and continue to calibration 2. I also didn’t have it full screen - not sure if that helped or not.
I faced the same problem and your solution helped. Thank you!
