Anyone else notice the camera dropping frames after the noise cancelling update. If you watch a print the head will just all of a sudden be in a new place over and over again. Appears there’s some sort of smoothing trying to be applied. It’s not a1 or p1p bad, still a smooth video. But it was better before when it was just live.
Yes, same here. Dropping frames on video feeds to the handy as well as the slicer running on a PC.
Can confirm that on my end, ios, PC(Orca/Bambu)
Having nothing but issues since the latest update “fixing” the motor noise. Literally hit print after the update and calibration and get failures. I now need to perform full calibration each print as it starts printing sometimes well above where my Z offset should be, there are blobs of filament on the nozzle and it is not cleaning properly. We are having terrible first layer adhesion and yes the camera is having issues too now. Not overly impressed considering we run 8 X1 carbons. Yes we have tested all of them and they are all having the same issues. Nothing else changed from before the update. same filament, same settings, same sliced file, same AMS, same print bed, same nozzel.
Can’t confirm your issue @Bullet_Prxxf, printing works fine, maybe consider a factory reset or eight factory resets.
Same here. Orca and Bambu also. I also changed the wifi router but no luck.
Same issue for me since motor noise update. For me it seems confined to stream within the Handy app and not so much within Studio. Sad to say, but I used to watch my prints live via handy app when I got tired looking for shows to watch on Netflix. This soothing experience has since been killed with the choppy stream since the update. I’ve submitted a ticket and would encourage anyone else to do the same if we hope for a resolution .
Same with mine I watch my prints to make sure they are doing ok but the sever cuts out or its laggy.
It is the X1C That has this problem.
