Can anyone help me find the name of these connections so that I can buy some of my own for some electronics projects?
They are the 6-pin and 4-pin connections used all over the machine. Here is a link to the store with the cable for the back of the AMS as an example:
I am looking to find the female and male versions of the 6-pin and hopefully the 4-pin as well.
Thanks!
Hi search for molex connector. I use Molex 2451320620 for my ams unit because i musst put my ams on the right side of my p1p printer.
Thank you for this! I am seeing these are all the female ends. I am looking for the male connector. Just the terminal or even a cable would be fine. I will look through mouser and see what I can find the model number you gave me. Thank you!
J&D 2er Pack ATX 4 Pin CPU Männlich auf Weiblich Verlängerungs Kabel - 20cm Amazon.de
It looks like 0430200608 are the male ones that go on the end of wires.
https://www.digikey.com/en/products/detail/molex/0430200608/4481507
Thank you! The “Micro-Fit 3.0” is the key part here, as I found by first buying a “standard” ATX 4-pin connector, which is way to big to connect to the printer port. The “Micro-Fit 3.0” is exactly what’s needed. I got this one https://www.amazon.co.uk/dp/B07Z6BJCVH if it helps anybody
Now I need to find the pin assignment - does anybody have a relevant link Thanks
