Can Bambu Studio access the printer directly in LAN Only Mode?
If I set the printer to LAN Only Mode, can I still access it via Bambu Studio ?
Added support for LAN only mode.
In LAN only mode, all data exchanged between printer and studio will be carried in the same LAN, without connecting to the cloud. For access authentication, Bambu Studio needs to use the access code of the printer, which is displayed on the printer screen.
Bambu Studio can detect LAN-mode printers. After user selects a LAN-mode printer, A dialog is prompted for the Access code. The access code can be refreshed on the Printer screen. After a refresh, Bambu Studio will disconnect and needs the new access code to connect to the printer again.
This is straight from the Bambu’s Wiki
firmware-release-history
Bambu Studio doesn’t find the P1P if it is set to LAN Only Mode. I can ftp to it fine using FileZilla while its in LAN Only mode.
I wonder what I’m doing wrong ?
Could be the Firewall on your OS blocking it.
Thanks. I enabled inbound as well as outbound and it works now. I have to select the printer from the device list every time I run BS and stay logged off the BL server otherwise BS still tries to connect to the printer via the cloud each time I load BS.
