I’m building some pieces to hold my laptop and docking station and other computery things vertically.
It’s basically two parallel rectangular walls with some rectangular “beams” running between them, plus some trapezoids on the outer surfaces of the walls so I can slide-mate multiple related pieces together.
I cannot figure how to print this thing without just tons of support, and it sure feels like there’s got to be a better way. Is there a way to configure the slicer to cantilever some support arches out from the walls themselves? I know it’s legal to cantilever layers at least a little bit; there’s some overhang angle that’s allowable. Seems like it’d be printable, if only the slicer would try.
As it is, the best slice I can get looks like this.
I’m spending all sorts of support plastic and print time on my handy slide-mating bits, and not much less on support for the “beams”.
And if my cantilever idea’s a non-starter, is there even something I could tweak to make the trunks of my tree supports narrower? I’m not holding up huge masses here; I’m not sure what I’ve got dialed such that they end up so thick.
Thanks!
