Hello. I have p1p and Ams. Probably stupid things but : after work I must put all material in the box the or I can leave the filament spool inside the Ams ? Thanks a Lot
You can leave it in the AMS
Great! I hoped it. Thanks for your time.
I have added supplemental desiccant to my AMS along with a hygrometer. I am seeing <10% humidity inside which is the same as I get with my dry boxes. So based on this, leaving in the AMS is fine.
Same ~10% I am reading too. I printed holders for loose desiccant in the built-in rear bays as well as at the front between the feeders. I don’t bother putting my filament away from the AMS given all this. My regular storage method is using the re-sealable vacuum bags with desiccant when not in the AMS.
