Can not choose parts \ skip objects
Hi! When I want to choose parts to print in a multi part profile, or when I want to skip some part during printing, I can not. I see instructions on top of controls and I can not pierce through those instructions. The only thing I can do is to press my phone’s “back” button to return to previous screen.
My phone is Nexus 6P and Android 8.1
It’s possible the app it’s as good with your version of Android as you have a model that is a few years old now.
Just-in-case, have you tried the back button?
Sometimes on Android apps, the overlay window is a normal window in the hierarchy and earlier versions of Android needed a back button gesture to dismiss the window.
I don’t have any Android phones these days (had 20+, I used to develop apps for them) so I can’t confirm.
Back button which you can see left to the title is also blocked. Only system’s back button works.
The one on the row of three buttons on the bottom of the display.
Yoggoth, the same thing happen to me yesterday on my android App. I dismissed it as a fluke and did it on my X1C screen but now I need to see if it is a new “bug”. Will test when i have another print going.
I can confirm this problem: I’ve got Bambu Lab 2.14.0 installed on a Motorola phone with Android 11 and on a no name tablet with Android 13. On both devices I can’t get past the overlay window.
Same issue on my galaxy tab a9÷ tablet running Android 14 but if i use my S21 ultra phone also android 14 the entire page is visible and has a “Got it” button at the bottom that once pressed closes the window and allows object selection. Seems to be a simple issue that the window needs to allow scrolling.
FYI, you only get the page once, as soon as you hit the Got It button the page no longer appears. Unfortunately its a per device thing so I do cannot use the tablet to select parts but my phone works fine.
Exactly the same issue… Samsung Galaxy Tab A (2016) Android v8.1.0 won’t scroll down to ‘Got it’, but Blackberry BBF 100-1 Android v8.1.0 will…
I see now it is fixed. Thank you.
If I skip objects, does the app center and orientate the remaining object(s) or are skipped ojects simply removed from the plate? Thanks
Welcome to the forum! Everything on the build plate stays the same, the print head just stops moving to the skipped objects and doesn’t try to add more layers.
