Can we add third-party bed types to BS?
I’m often using a WhamBam PEX plate. Is it possible to add this as a bed type in Bambu Studio?
As far as i know you cant add custom bed types
Wham Bam provides ArUco stickers with the PEX plate to identify the bed as a high-temp plate. The plate type is used to index values in the filament profile and select behaviors in the machine start G-code. Introducing new options would mess that up.
Good to know. I did apply the sticker but didn’t know it ID’d the bed as a High Temp Plate.
Easy enough to work with it now. Thanks!
I just started using the Lightyer G10 plate on my X1C, you need to increase bed temps 5-10 degrees, and the perfect sweet spot for it is 60 for PLA and 80 for PETG, and it’s flawless, problem is - now I have to make duplicates of every filament type and keep track of them all, anyone have a better way to organize the setting? It also makes it so I can’t ever print from Bambu Handy using this plate unless I want to create custom filaments from scratch for every filament I use ;_;
