Can we disable prime tower when using the customizer?
Hello. I found that when download from a customizer model, if the space is all taken and there is different color. there is no space for prime tower and the download will failed.
I found that using this model:customizable cryptex, Build your own now! Remixed by Shawn - MakerWorld
when there is more than 8 rings(start with 9) there is no room for prime tower. but if I remove the color, it just work fine. Personally, I never use prime tower and the color work fine. Can we default it to no prime tower? Thanks.
You can remove the prime tower if you wish, it is in the Other Settings panel. It’s not advised and so will probably not be set as the default. You can create your own profile and set it to have the prime tower disabled though.
You don’t understand me. I mean in the customizer when you click download button. it will try to create a 3mf with prime tower, which will fail the download because there is not enough space. I want the 3mf downloaded by default has no prime tower.
