Can we download different models on to same plate?
I want to print different small models at once to try them. Regardless of setting i select i could not managed to download additional model on to the existing plate.
If I tick " Keep only one Bambu Studio instance". The second model does not download at all.
If I untick it, the new model is downloaded in to a new BS instance.
The only way i can print multiple models is by downloading them manually into folder than loading them one by one to BS.
I am new to BL ecosystem and BS. Am i missing a setting to tick/untick?
When you use this to subsequently select multiple stl’s, you can import the objects as an assembly or individually.
Instead of “open in bambu studio” select “download 3mf” (or download stl if designer uploaded stls). then instead of open use “import” an then on subsequent dialog select “import geometry” - that will place items onto the plate and you’ll be able to arrange them to your liking.
I too download them first and importing but it would be easier if we could download them directly in to BS. I think it is not possible
It can’t be possible, as the 3mf file contains printing information and not just the 3D model. If there would be an option to open the STL file out of Makerworld, it would make sence to select more than one model.
