Cannot change nozzle size for my A1
I installed a 0.8 nozzle in my A1 but it won’t allow me to change it in the settings. Even after I did the select the printer with the 0.8 nozzle size selected, all it shows is hardened or stainless steel and .2 or .4 when I try to change it in printer parts
Have you tried create printer ?
A1 0.8 is hardened steel nozzle
Under printer it does say 0.8 nozzle. But I get a warning when I go to print that says
“Your nozzle diameter in sliced file is not consistent with the saved nozzle. If you changed your nozzle lately, please go to Device > Printer Parts to change settings>”
Except when I go to printer parts I can only select 0.2 or 0.4 nozzle diameter.
do you have an image of the new preset and device page and which version / build of bambu studio are you using ? my printers are not online at the minute
Bambu Studio | Bambu Lab Wiki
I finally got it. You had the answer in your first post, but I didn’t see it. I had to choose hardened steel apparently. Once I selected that the 0.8 was available.
Thank you!
You have to change the nozzle on the printer.
