Cannot connect to printer from Studio or Handy
Recently, I have lost wifi contact with my P1P/P1S upgraded printer. The printer display shows a valid local address, which is fixed and which appears as expressif in my wifi scanner. However, neither Studio nor Handy can connect to the printer. Display screen on printer says I am not logged in. Thoughts?
Welcome to the forum.
Sounds like you need to re-pair your printer?
It is paired. It shows in Handy and Studio, but will not connect.
Does your wifi network have 5 GHz and 2.4 GHz available for connecting to? From what I had previously read your printer may try to connect to the 5 GHz connection even though it only works on 2.4 GHz, effectively breaking the connection. Disconnecting and reconnecting wifi can potentially fix it.
Problem solved. Deleted and reinstalled printer. Now back to the problem with flow.
