Cannot disassemble AMS
I watched 3 or 4 youtube videos that show removing the guts of the AMS from its enclosure. After removing the tube and the two screws they show the inside being lifted out. But when I try this I cannot lift it out because the lever that releases the tubing blocks it. This is what it looks like …
Can someone tell me what I’m doing wrong?
I kinda push the button thing down while flexing the case out around it. Be carefull after that because the cables are barely long enough.
Same thing to reassemble
Pointer fingers on the button, thumbs pushing on the outer case and the rest of your fingers pulling back on the internal part.
You may also try and pull the button cover off first. Ive honestly never thought about that until just now. May give more room.
Thanks. That did the trick.
Your supposed to lift the inside out a bit then release the tube connector.
I did the hydra mod on mine so it does come apart. The hydra mod page has disassembly also so dose bambu wiki
