Cannot open or install Bambu Studio 02.02.1.60 under Ubuntu 24.04
The application does not open or install.
Trying with last 3 public release builds (non-beta)
(2.2.1.60) Bambu_Studio_ubuntu-24.04_PR-8017.appimage
(2.2.0) Bambu_Studio_ubuntu-24.04_PR-7829.AppImage
(2.1.1) BambuStudio_ubuntu-24.04_PR-7292.zip
Ubuntu 24.04.3 LTS
Error as follows on running the AppImage
Squashfs image uses (null) compression, this version supports only xz, zlib.
ERROR: appimage_shall_not_be_integrated : sqfs_open_image error: /home/REDACTED/Downloads/Bambu Studio Update/Bambu_Studio_ubuntu-24.04_PR-8017.AppImage
AppImageLauncher error: appimage_shall_not_be_integrated() failed (returned -1)
ERROR: appimage_is_terminal_app : sqfs_open_image error: /home/REDACTED/Downloads/Bambu Studio Update/Bambu_Studio_ubuntu-24.04_PR-8017.AppImage
AppImageLauncher error: appimage_is_terminal_app() failed (returned -1)
On trying to integrate the AppImage a second error is produced
fuse: memory allocation failed
squashfuse 0.5.2 (c) 2012 Dave Vasilevsky
Usage: squashfuse [options] ARCHIVE MOUNTPOINT
(null) options:
    -o offset=N            offset N bytes into ARCHIVE to mount
    -o subdir=PATH         mount subdirectory PATH of ARCHIVE
    -o notify_pipe=PATH    named pipe that will receive 's' (success)
                           or 'f' (failure) when the mountpoint is ready
    -o timeout=N           idle N seconds for automatic unmount
    -o uid=N               set file owner to uid N
    -o gid=N               set file group to gid N
FUSE options:
    -h   --help            print help
    -V   --version         print version
    -d   -o debug          enable debug output (implies -f)
    -f                     foreground operation
    -s                     disable multi-threaded operation
    -o clone_fd            use separate fuse device fd for each thread
                           (may improve performance)
    -o max_idle_threads    the maximum number of idle worker threads
                           allowed (default: -1)
    -o max_threads         the maximum number of worker threads
                           allowed (default: 10)
(null) options:
FUSE options:
(null) options:
FUSE options:
Can't open squashfs image: Bad address
Cannot mount AppImage, please check your FUSE setup.
You might still be able to extract the contents of this AppImage
if you run it with the --appimage-extract option.
See https://github.com/AppImage/AppImageKit/wiki/FUSE
for more information
execv error: No such file or directory
As far as I am aware, fuse is fully working as I have other file systems such as network shares mounted under fuse.
I believe there might have been some changes made to Ubuntu recently, notably with AppArmor but this is just a guess.
I have also tried the flathub version where i get
ldconfig failed, exit status 256
libfuse2t64 is already the newest version (2.9.9-8.1build1).
$ ./Bambu_Studio_ubuntu-24.04_PR-8017.AppImage --appimage-extract
This doesn't look like a squashfs image.
Failed to open squashfs image
