I have 3 PLAs and one PETG in my AMS and when I try to choose PETG to print, the AMS or Bambu Studio does not allow me to. Any ideas why?
You can’t choose PETG because the model was sliced for PLA…
Makes sense but if I change all of the AMS slots to PETG, it works. Thanks.
That is not a solution. If the model was sliced for PLA it’s not going to go well trying to print that file with PETG.
Thanks again. I’m still a newbie and love learning all this new stuff! I had no idea that slicing would be different for the different types of filaments and my next task is learning how to slice for different filaments. Any thoughts?
You select your filament and its settings there.
Then in the AMS page you showed it offers slots that are compatible with that.
Thanks. I’m good with this part. I can’t figure out why I can’t choose PETG when my other 3 AMS slots are PLA.
If the thing you’re trying to print was sliced in PLA, then PLA is all you’ll be able to select. No matter what is where or anything, nothing else matters. You will not be able to print it in PETG until you slice the file and select PETG as the filament BEFORE it’s sliced.
To expand on what @R3d-Five said, the reason behind this is because the sliced file has the nozzle temperature and filament profile in it.
If you try to print a file sliced for PLA with a nozzle temperature of say 210c then printing it with PETG will cause a lot of troubles as the nozzle isn’t hot enough to properly print PETG. The file needs to be resliced with the PETG profile so that the nozzle temperature is correct for that type of filament inside of the gcode file.
Further to the comment about a model having been sliced to PLA, my question is how do you slice it to PETG if when you opt for slicing options all you get a PLA filament grouping?
Is the only way, to pull the PLA filaments out of the tubes so that the PETG is the only “live” filament recognised and available in the AMS, and then going through the slicing process on that basis?
No, just add the filament (the + button) you want to use to the side bar in Bambu Studio.
Right click the model → “Select Filament” → ensure that the model is going to be printed using the filament you want from your slicer palette. Usually defaults to “the first” but not always
Another way to change the filament a model is sliced with is to select the model and punch in the number of the filament.
Example:
The picture above. If you want the model to be sliced with esun pla+, click the model and press the “5” key.
I was having a similar problem and what I discovered was that because I had originally sliced the model with PLA (to test the prototype) before printing it in PETG that no matter what I did it wouldn’t let me slice it in PETG. Once I saved my file it stayed like that.
My solution was to export it as an STL and then reopen that STL in Bambu Lab, Then it was simple to select the PETG filament and re slice it. All the way on the top left is the File menu and if you click on it you will find the export sub menu.
