Trying to setup my new printer through BambuStudio v.1.03.00.25. Printer is on the network with valid IP. BambuStudio has the network plugin installed and is on same network.
In BambuStudio I see my device listed under “Other devices”
Everytime I click on “would you like to log into this printer with this account” (mine - same as above) I get: Login failed(code=-1,info=(“method”:“post_profile”,“ret”=“0”}). On the printer I get “Unauthorized user”. How do I connect to my printer?
I have the exact same issue. How did you solved it? I tried everything.
