Can't print file as is
I recently obtained an STL file from a web site that has 3D print files for model railroading. The file
won’t print, even with supports, as it is a single entity composed of 310 objects, most of them are
floating in mid air. I tried to ‘split’ the file into objects, but can’t figure out how to group them and/or
place them onto the plate so they’ll print.
Any insist would be greatly appreciated.
Without seeing what’s going on it’s difficult to make solid suggestions, but I would probably open the file in a mesh editor to break it down into manageable pieces, then bring them into Studio.
3DBuilder is good, but you have to do some digging for that. There are lots of others.
You may be able to ask the vendor for assistance.
If the file is sold commercially, they usually provide a photo of a print, just so you know it does print. (Unless they already have an established reputation)
My son and I are working with something similar I think. He was given a badge design and asked if it could be 3D printed. Now he’d like to colorize the badge, but it cannot be broken down. So, he’s building an entirely new file from it to make it into separate parts.
Your file may be similar, from the sound of it. Taking a picture into a 3D file is one thing. But breaking it into separate parts is quite another. Whereas, if it was 310 objects presented as a single picture you could likely work the individual pieces.
None of this is as easy as printing spiders or articulated dragons, it seems.
Could you maybe get a screen shot zoomed in whatever is appropriate to get it all in one image. Make sure X, Y, Z planes indications are visible. Also model itself would be good. Someone mentioned a mesh editor which I use Fusion to do that. I find myself having to deconstruct models to be able to edit them and that can be pretty tedious.
I’ve tried breaking project into separate objects in Blender, but s/w isn’t dong what it says it should. Very frustrating. I’m trying to contact the author, but for whatever reason that is as difficult as
trying to work the image in blender.
Assuming you are using Windows, what happens if you right click the thing in the slicer (Bambu or Orca) and select repair? Sometimes that will fix very broken files. Sometimes it does nothing. Sometimes it completely breaks the object but it’s a free and low effort thing to try.
