With either my X1C or H2c cant get anything sent to printer. Have to use send then print. But amazingly Bambu status says everything is fine… Its been 2 days. You keep making new printers but cant fix your crappy network.
If the Bambu Cloud service were actually down, the forum and Reddit would be full of complaints. Right now, the cloud seems to be working quite well, as confirmed by countless successful cloud prints by many user the past days.
I’m not saying the network is perfect, but this sounds more like a local issue than a general cloud outage. To help troubleshoot it, more information would be needed:
Is it related to your router? Could it be your internet provider? Have you tried using your phone as a hotspot to see if the problem persists? Have you tried sending the print job through the app?
Without details like that, it comes across more as a rant than a troubleshooting discussion. If you want some help, feel free to post about it; if it’s just a rant, that’s totally fine, too.
seem to be having the same issue !
A traceroute might tell you if anything is down or iffy between you and bambu’s cloud service.
sorry for my ignorance but how do i do that?
It’s a networking tool that uses a trick to ping every hop in the route data takes from your computer to another and gives you back the ping times. When there is trouble on a network it can sometimes find where the problem is.
But it’s not an easy topic to explain if you don’t already know some about networking. But there are good explainers online and examples. You just need to know what server to trace to and I believe Bambu has multiple. That’s where it might get tricky but if it was widespread others would be reporting it (and we have another in this thread) like Sharky said. And if it’s somewhere in between, the trouble might be at some common point to your data paths and likely will be fixed soon if not already.
Good luck though.
after trying multiple times to send the print , it finally worked. guess it must be a cloud problem. just find it weird that it has never happened before? maybe servers are overloaded from everyone using new printer
I used to work with a guy who had a sign on his office door - “the cloud is just someone else’s computer” - and it’s exactly right.
It’s tough to know what’s going on but your data goes back and forth between electrical signals, radio signals, and optical signals many times as it travels and hits lots of machines along the way. Anywhere in that chain you can have flaky interfaces, failing memory, failing anything, really. It’s actually pretty amazing it works as well as it does. Natural disasters that are now much more common can also cause problems.
And worse, data packets from the same communication can take different routes and even arrive at destinations out of order and need to be reassembled properly.
The big take homes are outages at the server end will have lots of people take notice while few or nobody else reporting issues tends to indicate it’s at your end or somewhere between you and the server. Thing is, even with a traceroute, if there was some badness along the way, all it does is tell you there is badness. It doesn’t fix the issue or notify those who could go hands-on to fix the issue.
And it can also be congestion. There are limits to how much data can flow and if some other part of the net has issues, traffic may get routed along the way your data tends to travel and possibly overload it for your entertainment.
In general, if you haven’t changed anything, and your interwebs is still working otherwise, problems will eventually seem to fix themselves.
went back to not being able to send prints today and yesturday! and bambu slicer itself shuts down on its own. i have no clue whats going on. maybe i should uninstall and install again?
It’s really difficult to troubleshoot other people’s computers but I suspect it is local - but no guarantee on that.
You could try a reinstall but so much depends on the system. What other things you’ve installed, what you’ve removed, if it is virus-infected, or maybe something else entirely.
Maybe someone else has experience with whatever is happening on your system, but I’m afraid I got nothing now.
The help you get can only be as good as the effort you’re willing to put into it.
That means providing a clear description of the issue, posting screenshots, trying the suggestions people give you in the comments, and giving feedback afterward.
At the moment, troubleshooting like this isn’t really going to work. Just waving your hand and shouting, “I have the same issue!” isn’t troubleshooting. This isn’t meant as criticism.
I’d recommend installing the Bambu app on your phone and trying it there. That way, you’ll at least be able to find out whether the problem is related to your PC or not.
uninstalled bambu studio and went back to version 2.07 . seems to be working for now ! thanks for all the replys everyone. lets hope they fix the issue soon.
ok new problem now ! went back to 2.07 it worked for a week and now when i try to load bambu studio it doesnt load anymore. so install 2.09 it loads ok but when i try to send print to print it tells be my original error cant send print??? WTF ??? is going on?
