Case does not fit
Has anyone tried to put the extension board in the case?
I am not sure what I could be doing wrong. The board is on the bottom and all the screw holes line up, but the component circled in green sticks up above the case side.
Mine fits! Did you remove the support under the top cover?
Actually, looking at your picture it seems like you missed it
I wonder if that was support material. I was not sure because it looks pretty solid with just a single missing line.
Well now I feel dumb. I just went to take the photo below and in daylight I can see the waves of the supports. Last night the light just was not good enough I guess.
@TomB thanks for the tip.
It looks like while I was fitting the parts together without the circuit board one of the locating pins was a little tight. :grin:
