Challenges with the Bambu Lab A1 3D Printer: A Detailed Account
Hello all! I wanted to type something up about my experience with the A1. It is not my first printer, but it is my first Bambu printer, and I have had(and have seen others report) several issues thus far, I just wanted to share the issues and solutions/workarounds I have discovered, in hopes of helping others have the same problems, also, any insight from those more experienced are appreciated.
Introduction: Having moved on from an Ender 3, I chose the Bambu Lab A1 for its potential for superior quality, speed, and color printing capabilities with the AMS. Despite high hopes based on glowing online reviews, my experience has been a mix of frustration and problem-solving.
Detailed Challenges and Solutions:
  1. AMS Lite with Top Mount - Filament Loading Issue: The first major issue was with the AMS Lite’s filament loading, particularly with Sunlu Matte PLA. The filament would halt mid-way in the Bowden tube, triggering a motor overload error. Upon closer inspection, I identified that the #4 position’s bowden tube had a sharper curve compared to others, exacerbated by the matte filament’s friction. The solution was reordering the tube braces included with the top mount kit, placing longer ones in front and shorter ones in the back. This adjustment relieved the sharp curve, resolving the issue. Additionally, for smooth filament transitions during color prints, I manually load each filament via the touchscreen, which has effectively prevented further loading problems.
  2. Bed Adhesion Troubles: Persistent bed adhesion issues were a significant hurdle. After experimenting with various recommended techniques, including washing the plate with soap, the most effective solution turned out to be a light coat of hairspray, similar to what I used on my Ender 3’s glass bed. This simple fix, along with removing the plate for application, has been consistently successful.
  3. Nozzle Smacking Infill: Some prints displayed the nozzle aggressively dragging across the infill, occasionally causing layer shifts. This was specifically noticeable with cubic or adaptive cubic infill patterns. Switching to Gyroid infill (and reportedly Honeycomb) eliminated this problem, offering a smoother printing process.
Conclusion: This post aims to share the hurdles and solutions I encountered with my Bambu Lab A1. While my experience might not mirror every user’s, it’s vital for both community support and manufacturer awareness. I hope this serves as a resource for others, especially those new to 3D printing, and encourages Bambu Lab to address these issues more promptly and effectively.
Thank you for sharing your experience. I’ve been holding off buying the A1 because I haven’t seen a full extensive review yet. Most reviews seem to be from people who are rushing to push a “review” before others.
I have an Ender 3 V2 Neo, and I’m considering the A1 combo for two reasons:
1- Speed
2- Not having to change filaments (and the multi-color printing)
However, I’m still unable to find a reliable comment on the speed factor. Having come yourself from an E3, how would you evaluate A1’s speed?
I know it can’t reach speeds of a core-xy machine, but the reviews talking about 13 or 19 minute, and even 49 minute benchies are confusing!
I know that my V2 Neo can print MUCH faster than the default speeds by using 0.28 profiles I download from the internet. Even 0.2 profiles can still provide considerably faster print times than default 0.2 options, and the quality would still be decent. So taking this into account, how would rate the A1 speed ?
Thanks!
Get yourself the Bambulab Slicer and set it up for the A1. Then you throw some stl files at it and you can see the predicted printing times it calculates. You can even play around with differnt settings an see the differences.
He’s right, you can see the actual times if you download Bambu studio, but the A1 is right at about 3x faster than an Ender 3. So a 9 hour print on the ender, will about 3 on the A1.
But you can push those speed quite a bit higher on the A1. It’s all about how you slice it and how you tweak your settings.
