I have a P1P with the AMS, enclosed, aux fan, mainboard fan, and chamber fan with charcoal filter, when doing multi colored prints with the AMS my chamber fan cuts off when swapping filaments. Is there a way to stop this from happening so I can keep it running with my door cracked open? I have been taking my front door off on any prints with filament swaps longer then a hour, with the dual sided textured plate I start seeing the chamber temp climb over 35C when doing multible filament swaps on each layer and I would like to keep the door cracked and not have the chance of heat creep. Before I added the AMS I was able to do 10-15 hour PLA prints with the door cracked without any issues but thats with the chamber fan running the whole time. I guess one option now since the recent update is to go into the menu on the printer and just turn it on, I have not tried this…but I start alot of prints when I’m not home so that really isnt a solution.
You can, yes, but I’m skeptical that it will make that much difference. Click on the pencil icon to the right of the filament type. Toggle on “Advanced” if not already on, then select the Advanced tab. In the Filament end G-code box, remove “M106 P3 S0”. Save this as a user preset and then select this preset before slicing.
Thank you for your response, I see the same fan command in Machine End G-code so im assuming it will still be shut off at the end of the print.
