Chamber fan making a loud noise all of a sudden P1S
I have had this for about 8 to 10 weeks. Has been working great except for a few “filament stuck in extruder” errors. All of a sudden today while printing PLA the rear exhaust fan started making a loud noise. I can’t tell yet if it is a bearing or if it is spinning abnormally fast. I would appreciate any suggestions
How often do you clean out the chamber of the base of your printer? It gets awfully dirty down there.
If you have a sudden noise in any fan, there are usually two dominant causes. A) fan bearing is defective. Not likely in this case since Bambu fans are non-bearing fans. That means when they fail, they just stop working, they generally don’t make noise. B) Contaminant that has clogged in the turbine blade. Most likely cause. That’s why the question of how often do you clean the bottom of the chamber.
Either cause is easy to fix but the second cause is the easiest. Just disassemble the fan and look for debris, if found, remove said debris and reassemble.
In the case of a defective bearing, the fan will have to be replaced. Keep in mind that the Bambu power system utilizes 24Vdc whereas most PC fans are 12Vdc.
Which reminds me of a story last summer where my friend asked me to repair his Son’s overheating laptop.
His Son Loves sunflower seeds. Laptop? Not so much. Once removed from the fan “Viola” overheating problem solved. :joy:
I had the same problem yesterday. All of a sudden the chamber fan starts spinning with 100% when the print starts and that thing can get very loud… I had to manually switch it of through the mobile app. I checked the slicer settings and it wasn’t activated anywhere. I did three prints yesterday and had this issue with all of them. Had no time to do any further throubleshooting. Maybe your printer is doing the same thing?
Probably a normal thing. Remember, the chamber fan speed is controlled by the bed temp. If you print over 55C bed temp, they know the chamber will get very warm so they spin up the fan to 100% for PLA. At 45-55C, I think its around 70%. Under 45C, its running around 50-60% (can’t remember). But you can check the exact speeds in the slicer’s Start GCode tab.
Have you found the cause of your problems? I just got the same issue as the one you described
Same problem here i fixed it by putting bed temp at 50°C in filament settings fixed the proplem.
Hmm… same problem here. I haven’t made a print in 1-2 months. Didn’t had this problem. But now the fan is at 100%. Pretty loud.
No idea why.
EDIT: It seems that the FAN chilled out. It was only at 100% while the printer was doing it’s preparations.
Anyone narrow down this issue? I’ve had the printer for a few months. Just today the chamber fan just started doing this. It’s spinning so fast I’m a little concerned it gonna blow or short something. It seems to spin down after the preheat and bedleveling but this started out of no where and I’d like to know why before my $800 printer just up and quits.
I report myself having the same issue.
The fan goes to a 100% when the machine self levels and do the preprinting preparations. It started occuring all of the sudden… maybe an update caused this?
My X1 started doing this as well a few weeks ago. But mine sounds more like slightly worn bushing that sorts itself out after running for a few minutes. Or if I set the speed to 100% (from 70) for a few seconds and drop it back to 70 its fine again.
My fan goes to 100% if I select High Speed PLA filament. Even if I go to filament settings and disable the chamber fan. Selecting regular PLA this doesn’t happen. When printing PLA I open the top glass of my printer, what makes the fan noise worse. Slowing it down below 70% makes it better.
I believe Bambu changed the code under the PLA filament profiles to spin the fans faster when bed temp is above 55. The code is in the “advanced” tab in the filament profile.
I think this is to prevent extruder jams from warm (and thus softened) PLA - this can happen on long prints if you don’t open the door and lid (I’ve had this happen more times than I care to admit).
I’ve overridden the code for my profiles because it’s quite loud for my liking, I just need to remember to keep the door open…
Having the same issue following very soon after receiving the printer. The printer also had extruder errors from the moment it was switched on, it couldnt even print benchy. Im struggling to get a replacement from bambu and am starting to feel like I was ripped off by purchasing from them. Unlikely to get my next printer from here at this point.
