More and more users are building, or printing enclosures for their P1P devices.
Therefore, it would be desirable to be able to activate a chamber fan control for retrofitted chamber fans.
It should be possible for this possibility to specify parameters that the fans and temperature sensors to be used must fulfill.
Or even better to offer this as a spare part.
I am not sure, but I think I saw this option beeing in the SoftFever BambuStudio fork. Within the filament settings there is a “chamber temp” setting. On the other hand , I don’t know if there is a connector for a chamber fan on the MC board on the P1P.
cheers from switzerland
have looked at both boards.
On the X1 the chamber fan is connected to the conector “Fan_1” and the component fan to “Fan_2”.
Both conectors are present on the P1P board.
So I think that the chamber fan could be activated by the firmware.
What I have not yet seen where a temperature sensor for the camera is installed.
And yes I know you can build the whole thing yourself, the parts for it I already have here, but it would be more elegant about the firmware.
