Chamber Light Button on the Home Screen
It would be nice to have the chamber light button on the HOME screen and not on the second screen. Too many steps just to turn light on or off.
Which printer do you have, and how often do you turn the light on and off?
With the H2X, you’re supposed to leave it on while printing; otherwise, the cameras/sensors sometimes don’t work properly.
Thank you for your reply.
To turn the chamber light on you need to go the second tab on left then press the lower right button to turn light on or off and most of the time the screen is on the Home Screen so it is anoying to hit so many screen touches to simply turn the chamber light on or off when the home screen has so much screen real estate available. I simply suggest to add a chamber light switch to the home screen.
